Hi everyone. I'm building a multirotor octo . I have everything I need to build it (you can check my previous postings in other threads for my system specs) but I'm a little confused with the DJI WKM' powering/wiring setup. Please could you guys correct me if I'm doing it wrong or give better suggestions? First of all I'm going to use a 6S 10000mah(at 22.2V) single lipo for the main battery. I'm planning to solder a wire harness with xt60 connectors for my hobbywing 40a platinum ESC's. After parallel connecting the esc's powers ; this is where I get confused, how shall I power the WKM ? while I solder the harness I'm going to add an extra connection for wookong m. Will that be enough ? Someone told me that I dont need to power the ESC's from the lipo because wookong does but that sounds a little weird because what will I do with the 2 power cables on the esc ? plus the voltage wont be enough to power the esc's I suppose that would come from the wkm.
Please could someone tell me the correct way of doing this ? I would be more than happy Thanks in advance.
