Hello from Scotland
Scotty
Hi All
First of all can I say a big thank you to one and all forall great information that passes between you guys and girls, you have been agreat source in helping with my builds. I have been dabbling with mutilrotorsfor a couple of years all as quad configuration, I started with Mikrokoptercontroller, then tried APM 2.5, and currently trying Wookong M, and going totry Super x in future.
I have built all my own airframes starting with carbon fibre,and now using aluminium, and moulding my own centre housings with glass fibre.
The Microcopter system I found to be a bit messy having touse their own speed controllers and setting up was time consuming and tricky.The APM was better and had lots of specs but again tricky and time consuming toset up, but both systems flew well.
The Wookong M is the system I am currently using and find itvery good, very stable easy to setup and easy to use, if the cog is correct andthe quad is properly balanced they fly very well, one system is carrying aCanon G10 using a 30c 8000 Mamp battery and MK3538 motors, the other a GoPro with 25c 5000 Mamp batteryand Roxxy 2827/35 motors.
Currently using spectrum radio system but going to tryFutaba 14sg to make use of s bus, both camera gimbals are bought servo type,the plan is to make brushless gimbals in the future.
