Having a problem with the new A2 Firmware v2.1
JDM66
Hi
after update the new A2 Assistant Software v1.2, everything seems ok in the wizard
then ...
impossible to calibrate, after 7 switch gps manual, led lights blue 1 seconds and then turn solid green ...
after several trials, led light red start accounting GPS
I try to start the engines, they start almost at full speed and then fortunately have stopped, CRAC BOUM ON THE FLOOR
DO NOT UPGRADE TO THE NEW @A2 Firmware* v2.1
I wonder why I still buy at DJI...
jdm66
Jumpy07
Lots of people flying 2.1 with no issues.. suggest you check your setup.. sounds more like an rx issue.
JDM66
I have a set up with S800 A2 V.1.1
I made two or three flights to validate the operation, everything is OK
Not having any more confidence in my S800, I decided to use my A2 on a F550 (flight no stress)
I disassembled the A2 from my S800, I update V 1.2 and install it on my F550.
The problem happens now <label for="rb_iconid_8">
</label>
In your opinion where is the error ?
jdm66
CG Photo
I am finding that the V2.1 update works great on both my S800 and F550. This update fixed all the bugs in the A2 for me and it is more stable than the Naza V2 ever was.
hi folks,
i changed the thread title to something more reasonable. i'm not saying the firmware isn't to blame, just trying to get the focus on the problem the OP is having.
i'm not sure i see how it would be a Rx issue, i'd suggest a review of all connections and that you double check the firmware was updated properly (as in exactly as it's outlined in the manual)
