Hello, hello! So I have selected parts for my first 4-rotor multi and first TX/RX set up. I'm pretty sure it will fly as it's similar to other builds I have seen that fly really well, but I am still unsure about a few aspects that will affect the ability of the craft to fly well etc.
Selected parts so far (all able to be sourced from HK although I can source from anywhere that will ship to NZ in a timely manner and fit in the same price bracket):
My main concerns:
Prop: I'm not sure whether there will be a good reason to choose the 10x5 vs the 10x4.5 ones and whether they need to be of a higher quality, as I will need to learn how to balance props anyway. But roughly this is the size of Prop I think I should swing with chosen motor.
Flight Controller:I figure I'll be able to get a lot out of the HKPilot gear, since I want to be able to program way points and loiter etc, and am happy to have to spend time tweaking the board and installing firmware. But I don't know where I should source one of these controller boards (are HK ones any good?).
TX/RX:The Turnigy 9XR Transmitter seems to be used by a lot of hobbyists and is very affordable, can't find any real advantages over more expensive units. I'm not sure on the compatibility of the OrangeRX units I've selected (one module for the 9XR as doesn't come with one and the receiver and I'm not sure about telemetry with this combo).
Any advise would be grand. I think the most important part is selecting a suitable frame/motor/ESC and prop combo. I just need to do my reading with regard to selecting an FC and sourcing good TX/RX gear. Also I've noticed a lot of people with similar requirements as mine flying wooden Y4 quads. I want to build an X-config, but only because I think that looks cool, what are the advantages there? I can google that too, but opinions?:black_eyed:
- Frame
- Turnigy H.A.L. (Heavy Aerial Lift) Quadcopter Frame 585mm
- Motors
- NTM Prop Drive Series 35-30 1100kv
- ESC
- Afro ESC 30Amp (flashed with SimonK)
- Props
- 10x4.5 SF Props (generic black ones from HK? Maybe a bad idea)
- Flight Controller
- HKPilot Mega V2.5 FC with GPS Module / other APM FC with GPS
- TX/RX
- Turnigy 9XR Mode 2 (No Module)
- OrangeRX DSMX/DSM2 2.4 GHZ Transmitter
- OrangeRx DSMX Spektrum Compatible DSMX 3Ch S.BUS 2.4Ghz Rx (twin long antennae version) (has S-Bus but I'm not sure about compatibility with FC)
My main concerns:
