GPS Puck Location?
dmetz
I currently have my Naza M V2 GPS puck mounted on a folding extension arm. While a very remote likelihood, I could see a set screw or something failing with this collapsible post. I'm thinking of moving my GPS Puck to a spare motor mount on one of the forward frame arms on my Tarot 650. This would eliminate the need to have a folding vertical arm for packing and transportation. Is there any real advantage to having the GPS on a vertical arm (pole) when you have ability to move it away from battery and electronics on a horizontal arm. I understand that wherever I locate it, I need to input offset dimensions in the DJI Naza V2 Assistant software.
PeteDee
Mr take no prisoners!
You could mount it low as long as it is clear of any transmitting device, batteries and receiving devices are not an issue. Have a look at how the guys mount them on their TBS Discovery's, towards the back near the receiver, away from the vTx, some mount them directly on the frame and they work fine.
I just have mine in the middle and have shortened the standard mount to make it easier to transport.
Pete
dmetz
Pete
Thanks for your response Pete. I felt like that would be the case but just want confirmation as it seems more conventional to see the Puck on some kind of mast, presumably to isolate it better from the craft or equipment. I'm assuming here also that mounting the puck directly (or nearly directly) to the carbon fiber frame is not an issue.
PeteDee
I would not expect a problem mounting directly but I do prefer it up a little, really all you can do is try it and see what happens, sometimes a small change in placement of equipment can make a big difference.
Pete
