Getting Mostly out of FPV,UHF Skylark Tracker/OSD/Archos AV500 DVR, Boss Amp Headplay
daign
I am selling a lot of my FPV gear because I've found I just simply don't FPV enough, in Los Angeles, antenna tracking is total overkill. There's really nowhere we can fly safely using common sense. Most of this stuff has just been sitting in my coat closet in. So lets begin. Lots of stuff!
Feel free to check my ebay feedback my name is "assembledinamerica"
Skylark Auto Antenna Tracker III, Only mocked up with patch and tripod to test. - $300
x
Brand new, mocked up never used once. USB cable purchased and included as well. (Programs OSDs and AAT) Original Box, cables (XT-60 power) and ready to have firmware updated and used. I just will never use it here in Los Angeles... A cloverleaf/skewar setup is fine for my use.
Archos AV500 30gb DVR Mint Shape! $200 shipped
New battery, replacement in/out cables, In/Out adapter (took a while to locate). Original box, instructions case, you name it. This thing could pass as new as was WAY ahead of its time.
Ralphie says buy me:
http://reviews.cnet.com/portable-vi...os-av500-mobile-dvr/4505-6499_7-31517717.html
New fresh battery and in/out adapter with new 3.5mm to RCA cables (allows external monitor after DVR. Awesome older DVR that records at 30fps in MPEG4 512x384 30fps. I haven't charged the thing for 2 years and just powered it up and it had half battery (new battery and new in and out cable/adapter (these were VERY hard to find). Plugs into windows as a USB device for firmware updates and video downloads. I just had to clear out my own videos. As you can see this was a badass device at its time. Its perfect for FPV. Records Mpeg4 29.97fpv Here is a few samples. One on Vimeo and one on Youtube. Both were Seawolf Pixims on 1.2ghz
http://www.youtube.com/watch?v=7KKW5rWh_Iw
https://vimeo.com/72166615?email_id...e_complete-finished-20120100&utm_source=email
daign
Skylark Dianmu OSD with RTH OSD Brand new in box $185 shipped
Ordered for a new bixler build. Since I'm selling off my skylark AAT I am offloading all my OSDs... This particular one has full Return to Home Failsafe.
http://www.skylarkfpv.com/en/product.php?id=25
Skylark Tiny OSD III with AAT GPS adapter. Compatible for AAT use. $89.99
Wired and ready to connect to TX and camera via Futaba connector!
USB dongle for control/firmware
Boss Video Amplifier. $15 shipped
Was wired into my ground station for a 2 outings before I realized I didnt need it. I spliced in a ec5 connector as well as a 2.1mm connector to connect to the 5 head splitters.
HD Video upscaler from analogue s-video or red/white/yellow composite to HDMI $30 shipped
I purchased it to be able to FPV from my big screen but never used it. Common sense kicked in and I dont want to be flying over my neighbors homes...
Compact, light weight, portable size.
HDMI in,Composite/S-video + Audio R/L out.
Convert HDMI signal to Composite/S-video + Audio R/L signal.
Supports high resolution HDTV input up to 1080p
Automatically detects and converts incoming HDTV resolution to NTSC or PAL formats
daign
Headplay 800x600 Goggles $290
Used twice (I prefer an LCD, I get motion sickness with these. Has Rangevideo Liberator protecion case/clip, 2200mah Lipo. Charges using the power brick just like OEM. Included are 2 extra OEM batteries, headphones, single headphone, power brick, case, different foam sizes etc.
USB dongle that comes with Headplay
2 OEM batteries
Still has the protection stickers on them!
New DPcav RSSI display for ground station. $29.99
Range Video Diversity, various Antenna Styles. PM if are interested in one or two.
1280 ReadymadeRC 8dBi patch antenna 1280mhz $20
4x Hitec A-FHSS 2.4ghz Minima Receiver with RSSI $20 each shipped
Arducopter APM MinimOSD new $30 shipped
daign
I forgot!
Rangelink Transmitter with Hitec/JR 3.5mm cable 2 Receivers, 2 antennas $250.
Mounted on my aurora 9 and tested once, Taken out for Photography. No real use for this length signal around here.
