Futaba T14 SG tx compatibility with a Futaba R6303 SB rx
jroestel
I just recently bought a new T14SG Tx that came with a R7008sb rx, it bind beautifully with the tx, at the same time I bought 2 R6303 SB rx that I thought were compatible with the T14SG tx but I did all the procedure and so far I could not bind the rx's despite the Futaba compatibility chart says they are compatile. Am I missing something?
Are they really compatible?
Thank you in advance for the help!
Quinton
I don't have one but they should be, only using multi or 7 channel though on your transmitter, 12 or 14 channel is not compatible.
PeteDee
Mr take no prisoners!
Not sure if that Rx is one affected but some will also not do S-Bus with some FCU's, the 7008SB is fine though.
