For sale- quadropower motor qc-3328 (cheap)
I have 8, QUADROPOWER MOTOR's (QC-3328) The original price is 92.00, i am selling them for 75.00 dollars each. ALL OF THEM ARE NEW AND HAVE NOT BEEN USED. If you are interested in purchasing one of them, please contact me at [email protected].
Technical Info
• Lithium cell count: 3-6
• Load current: max. 30A
• Maximum load current. (15 sec): 50 A
• No-load speed: 700 rpm / V
• Recommended Propeller Size: 10" .. 14"
• Mechanical power: 350 W
• Thrust max.: 2200 g
• Wire length: about 60cm
• Total weight (without cable): approx 105g (139g with prop adapters, 600mm wires, and bullet connectors)
• Dimensions: h=33.5mm, d=28mm
• Shaft diameter: 6mm
• 0.2mm stator laminations for low eddy current losses (lower Io compared to leading competitor motors for higher efficiency)
• High strength Neodymium magnets (lower Rm than leading competitor motors for more power)
• Genuine EZO japanese ball bearings
• Hardened & polished shaft
• Highest quality CNC machining in the industry
• Dual mechanical magnet retention (even if there is an adhesive failure, magnets will not dislodge)
• Pre-installed prop adapter and bullet connectors (plug & play motor)
• All-black finish for a professional looking installation
• 600mm long 16ga heavy duty motor wires ready for multi-rotor applications
• Short shaft design for interference-free installations
roversync
