For sale: AV200, AV130, Droidworx AD8 HL, MK 3538, Pelican 1730 and extra parts
blckdmp
Cleaning out the "hangar". Everything is in good-great working order. Some of the spare parts have some cracks as mentioned in their respective listings below. Lots of pics attached. Please look at them if you're interested in anything here.
  • AV130 w/ 360 pan camera gimble: literally flown once (not crashed :) ) As new. Comes with 360 pan and skids, Servos: Hitec HS-7940TH (faster than stock Savox) on both tilt and roll, and Hitec HS-7245MH on pan. All servos can run from 5 - 7.2V - $975
  • AV200 w/360 pan camera gimble: good mechanical shape. Works smoothly. Comes with Savox 1258 TG and Savox 1290 MG (stock Photohigher servos, 6V max I think) on roll and tilt. Hitec HS-7950TH servo on pan axis. - $900
  • Droidworx AD8 HL V2 multirotor frame. Never crashed. Comes with 8 arms (410mm), centre plates, boom clamps, motor mounts and aluminum gear rail brackets, and gear rail carbon rods for camera head support (see pic of underside). No dome -$675
  • MK 3538 motors: in good shape, they run smoothly. 4 with shorter motor cables (33cm) and 4 with longer cables (55cm) . Took the stickers off for looks -$35 each
  • APC 12x3.8 SF and SFP props: Pusher and "Tractor" pairs new in bag, never used. 8 pairs. - $4/ pair
  • Droidworx AD8 HL V2 parts: 8x 410 mm carbon fibre boom arms. -$175. 8x motor mounts (some cracking on one or two of the plastic bits (see pics) -$150. Boom clamp brackets for AD8HL (8 large and 8 small, one large is cracked in half, probably need to be replaced, see pic). -$30. Centre plates, top and bottom -$75
  • Pelican 1730 travel case. Lightly travelled, lots of small scuffs, but all hinges, seals and case integrity are perfect. Foam is cut out to carry 2 Droidworx AD8HL machines (with 4 arms loosened and folded in). It's a big case; please check dimensions online if you're interested. -$295
All shipping is actual cost from Canada, postal code V0N 1G1. All customs/brokerage fees are the responsibility of the buyer. Please check all relevant pictures and/or ask for clarification if you have any questions about what's included. Please email me (jon_ritchie (at) telus.net) as I don't check my inbox here that often.
Thanks,
Jon
xerofly
Thanks,
Jon
Hi
I need Pelican 1730 case..
cheers
blckdmp
New prices. See first post for pics.
AV130 w/ 360 pan camera gimble: literally flown once (not crashed ) As new. Comes with 360 pan and skids, Servos: Hitec HS-7940TH (faster than stock Savox) on both tilt and roll, and Hitec HS-7245MH on pan. All servos can run from 5 - 7.2V - $925
AV200 w/360 pan camera gimble: good mechanical shape. Works smoothly. Comes with Savox 1258 TG and Savox 1290 MG (stock Photohigher servos, 6V max I think) on roll and tilt. Hitec HS-7950TH servo on pan axis. - $825
Droidworx AD8 HL V2 multirotor frame. Never crashed. Comes with 8 arms (410mm), centre plates, boom clamps, motor mounts and aluminum gear rail brackets, and gear rail carbon rods for camera head support (see pic of underside). No dome -$575
Droidworx AD8 HL V2 parts: 8x 410 mm carbon fibre boom arms. -$150. 8x motor mounts (some cracking on one or two of the plastic bits (see pics) -$125. Boom clamp brackets for AD8HL (8 large and 8 small, one large is cracked in half, probably need to be replaced, see pic). -$30. Centre plates, top and bottom -$50
Pelican 1730 travel case. Lightly travelled, lots of small scuffs, but all hinges, seals and case integrity are perfect. Foam is cut out to carry 2 Droidworx AD8HL machines (with 4 arms loosened and folded in). It's a big case; please check dimensions online if you're interested. -$250
