Flyduino Nano :: Multiwiiconf :: TX no inputs
hi,
happy new year ...
i have flyduino on my mini quad ... and have a big problem with Multiwiiconf 2.1 ...
it recognizes the sensors but i just cant any inputs from the Tx on the screen to set ranges etc ..
the setup is ...
1. 2700 kv motors with 3 blade 5 x 3 props
2. 20 amp esc flashed with Simonk Tgy.hex (manually calibrated throttle range separately after flashing)
3. custom frame
4. Flysky rx (6 ch) and flysky 9x Tx
uploaded the sketch through arduino 1.0.3 .. uploaded successfully ... multiwiiconf shows movement of quad on screen ... but no response on the from tx ... also i noticed the rx light blinks rapidly ... and have check the bind without connecting to the nano as welll .. bind is good
stuck with this problem .... can you pls guide me ?
searched the net and tried most of the options .. with no luck ...:dejection:
thanks in advance
CH
