So I finished up my little Micro Quad build last night. The setup is basically the Turnigy kit but I completely built it from the parts rather than buying the assembled unit. HK Link
The crux of the problem is moto 1 starts spinning up right at about 10% throttle. M4 and M3 start up maybe around 20% and M2 doesn't start spinning until maybe close to 50%. A hair over 50% and the quad flips itself over and slaps itself onto the ground without the left side ever coming up.
The KK board has been reset and every setting checked out and matching what many other have done for a small quad. I'm not sure if the problem is potentially the ESCs, or the motors and their wiring because I did have some solder challenges with the cut varnished motor wire. I really thought I got them connected well, but I'm just not sure where to begin testing with the DMM and what I should check.
I have the KK2.0 LCD board and got the motors all spinning in the right direction and followed all the tips and tricks spread out everywhere. The stupid prop savers that come with the motors are complete crap, the props just go flying off once there is any speed over 50% on the stick. I learned that the hard way. The lame push props took some work to figure out I needed to bore them a smidgen but now they mount fine.
Any ideas or guidance would be very much appreciated.
<style id="_clearly_component__css" type="text/css">#next_pages_container { width: 5px; hight: 5px; position: absolute; top: -100px; left: -100px; z-index: 2147483647 !important; } </style>
