You've probably seen a post like this a thousand times, but i'd rather get it right first time and not spend twice!
I would be extremely greatful if you could look over these parts and make sure they fit and work together - if not, any advice would be greatly appreciated
(Below is all the basic components, I am aware I will need various other small addons to connect everything etc..)
Frame: Tarot 680PRO - http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=62739
FC: DJI Naza-m v2 - http://store.dji.com/product/naza-m-v2
Motors: Turnigy Multistar 3252 850kv -http://www.hobbyking.com/hobbyking/..._3525_850Kv_14Pole_Multi_Rotor_Outrunner.html
ESC: Afro ESC 30amp - http://www.hobbyking.com/hobbyking/..._Motor_Speed_Controller_SimonK_Firmware_.html
Batteries: 1 or 2 Turnigy 5000mAh 3s 25c - http://www.hobbyking.com/hobbyking/store/__9183__Turnigy_5000mAh_3S_25C_Lipo_Pack.html
Transmitter: Turnigy 9XR PRO (with added battery and 2.4ghz module) -
http://www.hobbyking.com/hobbyking/...Radio_Transmitter_Mode_2_without_module_.html
Reciever: Turnigy 9x 2.4ghz reciever - http://www.hobbyking.com/hobbyking/store/__12339__Turnigy_9X_2_4GHz_8Ch_Receiver_V2_.html
Props: Yet to be decided, depending on final weight.
Many thanks!
Many thanks!
