Multirotorcraft UK
I just wanted to let you know of a Possible bug in Wookong 5.06 that could cause inguriy if props are on...
I have found that if you execute CSC and lift the throttle a little then shutdown the throttle stick to 0% and allow the
engines to stop, if you lift the throtle stick within 5 seconds of them stopping you can re start the engines without Combined stick command. It gave me a bit of a start.
Just thought you should know.
My throttle idle is set at "recommended"
