Racerx1962
Some of you may have seen Stephen "Sleepy" Cinch's review of our plate designs back in June of 2015. We've since updated our line to include 4 main models: the F1, F2, F3 and F6. All model kits come with high-grade 2.5mm thick center plates (3k toray carbon fiber); rectangular aircraft aluminum booms (anodized in red or grey... 15mm wide X 30mm high in lengths from 29omm up to 500mm with a wall thickness of 1.3mm), retractable landing gear and standard carbon fiber motor mounts for quads, hexes and X8s.
All of these models feature integrated Lipo "winglets" on the top center plate for easy and secure placement of dual lipo batteries. They will accommodate lipo sizes from 4S 5000s to 6S22,000s.
The F1 (quad/X8) is ideally suited for long endurance/small payloads such as Gopro, FLIR Vue or small mirrorless cameras, with wheelbases from 625mm to 800mm.
The F2 (quad/X8) is a perfect rig for flying the popular GH4. Wheelbases are available from 735 up to 1160mm.
The F3 (quad/X8) is the flagship heavy lift frame for full size DSLRs and cameras such as the Red Epic or Arri Alexa.
And the F6 (hex/DODECA) is a solid hex platform that be used for any of the above... long endurance to heavy lift with the option of the 12 motor configuration.
The bottom plates and lower lipo trays offer provisions for most gimbal mounting interfaces, including the popular 59 and 155mm rail mount systems.
All frames can be "pivot" folded for easy transport and travel. The pivot styles are much safer and more reliable than the "umbrella" folding style copters that hobbyists fly. And because we use rectangular aluminum booms, there is no more messing with clamps/tubes and the potential for twists while in flight. Also, no need to spend time leveling your motors, as they simply bolt to the flat surface of the booms. And lastly, because we eliminate the cumbersome tube/clamp construction, assembling the Falcon frames are a breeze.
Additionally, we offer upgraded motor mounts in both 6061 aluminum and the stronger 7075 aluminum (for U7, 8 and 10 and KDE 7000 series motors), accessory plates for Flight Control electronics (with or w/o dampening), trays for extra lipo batteries, aluminum ESC trays and a unique high-amp Power Distribution Block milled from solid copper discs (36mm in diameter X 5mm thick with (12) 3.5mm contact holes... 72 grams of copper).
And we stock/sell individual parts should you need spares or extras. We also offer build services with complete RTF packages with your choice of Tmotor, KDE or custom motor/ESC/component configurations.
Falcon Drone Systems frames are industrial grade frames for professionals. So whether you are looking for a long endurance FLIR rig or a heavy lift rig for a Red or Arri, we have the package for you.
Check out our website at falcondronesytems.com, our Facebook page (Falcon Drone Systems) or contact us at skydronetech@gmail.com for inquiries.
