Hi Everyone
My new F550 crashed on its third flight. I could see it lost power on one motor. At first I thought one motor cable came off from the ESC, as this was one obvious possibility since a cable was disconnected after the crash.
So I replaced the one broken arm and prop, and fired it up for a test.
Surprisingly, one other motor would not work. Not the one that had the ESC cable off post-crash, nor the one with the broken arm/prop.
This may be what caused the crash in the first place.
I built this hexa to be very reliable. I used T-motor Motors, T-Motor ESCs and T-Motor CF 10x3.3 Props. And I built it carefully.
So I am intrigued by this fault.
The engine seems OK, as it seems to turn back and forth (Cw and CCw) rapidly.
I suspect it is an ESC fault.
Has anyone seen this before? Bew T-motor esc fault?
Here is a video of the failing motor:
http://www.youtube.com/watch?v=d4utIi4_HLo
I ordered a new motor and ESC To test, but I am curious if anyone had this before.
The only thing I am guilty of is that the aircraft was very heavy. It has a Zenmuse, GoPro, and a 11000 3S Mah maxAmps LiPo. But it flew nicely and didn't seem underpowered, and was hovering when failed.
Thanks!!
Thanks!!
