I have a 60W iron and some tin/lead solder (new to soldering and I found the lead free melts at a higher temp and I keep messing up when I have done it before, so moving to lead for this build until I get to grips with it). Do I need to prepare the surface and coat the connectors afterwards with hot glue or alcohol scrub? I assumed you just soldered the wires on and that was that, but with flux core solder it appears I may have to treat the connectors after soldering?
I have read about people using hot glue to cover the connectors to stop them rusting/corroding/shorting which seemed like a good idea to me as I have a hot glue gun - thoughts? If it isn't needed then it would make life easier removing the ESCs if needed thats for sure!
