F450 compass calibration
AndySV1K
Hi all,
After a little help please!
Just built my F450 and everything has gone very smooth so far.
Got connected to software and set everything up ok, all seems to be well, got motors spinning correct directions and I've even just had a quick hover.
But I can't seem to get it to enter calibration mode.
I'm on a DX6i and gear switch has been set up to do atti and manual. the software sees this working fine too.
Just can't get the switch to get it into calibration mode.
Any ideas??
Andy.
If your setup on the gear switch and only have atti and manual that is the problem you need to switch from GPS atti to manual 6-10 times fairly quick and stop in GPS atti mode and the light will confirm you are in calibration mode. So if your just going from atti to manual that is the problem!
It is really meant to be set up on a three position switch.
I just noticed you did not say anything about GPS so if you don't have a GPS puck there is no need at all to calibrate.
Just go fly and enjoy!
Hope this helps
AndySV1K
Aha!! That explains it then! You are correct I have no GPS.
I don't have any 3 pos switches either so can only use the A-M setting.
Now all I need is for the bloody wind to die down!!
Thanks for your help Suddenincline. :nevreness:
Andy.
Andy.
No problem good luck! :)
Jonathan
