F-450 ARF, KK2.0, Spektrum dx6i tx and AR600rx - need help - no signal
TheAliasOne
I bought the DJI F-450 ARF kit from my local hobby shop. He also sold me the KK2.0 board (with LCD) and spektrum AR600 rx for the dx6i tx that I already have. I got the base put together, soldered the ESCs and main power, and have been working through the rx to FC setup. For now - I'm using a receiver pack to power my rx which also powers the FC. I'm using a 2200 3S to power the main board that has the ESCs / motors. For the life of me - I cannot get the FC (KK2.0) to recognize any input from my tx/rx. I continually get a 'no yaw signal' from the FC and when i go into the 'receiver test' on the FC - i always have 'no signal' across all channels. I've tried replacing the male-to-male cables that connect the rx to the FC. I've actually unplugged the rx, plugged servos into each channel and tested - the servos work fine so I know the tx/rx are working. I've searched the internet, watched videos, read posts and am still stumped. I figured maybe my KK2.0 was 'bad' ... so i grabbed a KK v3 (Atmega328PA) from online and experience similar issues. I cannot get the KK v3 to arm either. I have tried replacing my dx6i with a dx5e -- same results ... no input to the FC but servos work fine. I'm beginning to wonder if maybe i need a "BEC" to power my RX (which then powers the FC ?!?) - or maybe am i powering everything on in the wrong order? I'm very frustrated as I'm not sure what else to try. My understanding was that the M1 would actually power the FC but when i don't use an RX pack to power the RX -- my FC never turns on.
I have not yet calibrated the ESCs because I was worried the ESC might not calibrate correctly if I have RX connectivity issues (but I honestly don't think it's a Tx/Rx issue). Anybody willing to lend a hand or some advice? Honestly - had I of known the headaches I've encountered - I would probably have bought the NAZA setup or skipped this whole project - but now I'm just stubborn and frustrated and determined to get through it.
Maybe if anybody else has used this combo with the ARF kit, KK2.0, spektrum Rx could give me a detailed layout, some pictures or walkthrough -- and do I need a BEC instead of powering my RX with a separate battery? If so - would it be best to find one without a ESC - just some kind of a voltage reducer to get from 11.1V down to the 6v for the RX ? I have not upgraded firmware on my KK2.0 OR the KK v3 yet -- might that be the issue? I'm open to pretty much any thoughts / ideas / solutions at this point. Thanks!!!
TheAliasOne
