Razzil
I purchased an EzOSD about two weeks ago now ... and since it's arrival I haven't been able to obtain the bottom line on the screen. The top line is perfect. I contacted the supplier and they sent me out a replacement current sensor. Plugged that bugger in ... and the same issue. I've updated the firmware successfully, from Immersons website with the font first and the firmware second as it states. I can even go into the configure portion and make changes. I've used multiple batterys to fire everything up (2x) 4S Maxamps 6000mah and (3x) 4S Maxamps 2250mah Lipos) all of which are the same results.
Images below are of the wiring, and the results. Don't mind the sats, as I'm next to the window inside. Not bad though considering.
The battery and video icons on the top are of the GoPro output.
Any ideas what's going wrong here?
View attachment 6678 View attachment 6679
I'm starting to think its no longer Ezzz
