All righty, I'm new as well but heres a couple of things I've played with on our smaller birds.
TBS Disco
Flew awesome w 2814s (no extensions) and 9" Graupners. Would likely have flown better w 8" Graupners but cant find any. Slight forward back wobble at highest fast forward flight (FFF)
Flies ok with Stock DJI motors and 10" Graupners. Slight forward back wobble at highest fast forward flight (FFF) Definitely less powerful and responsive than the 28144s.
Flies like **** with stock DJI motors and 9" Graupners. HUGE wobble at FFF
Conclusion - Will likely go back to 2814s and add brushless gimbal
DJI 550 - I'm a huge fan of this guy as he's soooo configurable, that said its got limits!
Flew the best w stock dji motors - 10" graupners - Iris Aerial Legs and batwing and hardmounted GoPro 3. Able to do flips rolls etc. Very little effect from legs but susceptible to jello. Everything must be balanced perfectly.
Flew very good w stock dji motors - 10" graupners and gotheli RC legs (taller than the Iris legs) which allowed a wire rope isolated gopro 3. best combo for toss in the car go flying with Fatsharks. Able to do flips and rolls but buffets slightly due to legs in FFF.
Flew ok with stock dji motors - 10" graupners and Aeroxcraft landing gear. Starting to get heavy here but allowed the addition of small servo gimbal. NOT able to do flips or rolls and FFF required a delicate stick. Wobbled a ton on descent but new Naza FW seems to work better for descents across the board. Still a good size for backseating in the car but starting to creep in size and footprint.
Flew great but worked like **** with AMP motor extensions, tmotor 2814s, 12" Xoars and Quadframes LG and Musky Gimbal. This is where the limits of the frame start being felt. TONS of friggen power - rocket ship power in fact and no worries hauling everything plus the two 6000mah batteries. Unfortunately this COMBINATION resulted in so much vibration the frame was unusable with this gimbal. I suspect this is due to two reasons. one the Quadframes Landing gear lets a ton of vibration through and the motors are simply too powerful for the arms resulting in twist. At this size its just as big as the AD6 and you've lost any footprint advantage. Considered moving everything onto one of the new Tarot folding frames for 300 bucks as Components this good deserve a better frame. Ultimately, just created a quick release rail system and moved this gimbal/LG onto our droidworx framed coax 8 which works much better. Moral of the story here is...if you're lifting anything other than a gopro or small pointn shoot a better frame is probably in order. Conclusion; Will take this guy back to its 550 stock"ish" configuration w small brushless gimbal and decide on Iris or Gotheli legs or aeroxcraft LG based on how much clearance is required.
