F
fengshuidrone
Guest
I used my EZ GUI Multiwii logs converter to make a csv file out of my flight logs. Then I exported that file to this video software that can sync up the csv to the avi. It's called DashWare. It's free from Go Pro but you can sync it to any cam's footage. With this program you can add instrumentation from the telemetry received in flight to your onboard cams flight footage for a final video with OSD of whatever telemetry info you want to portray. You can create your own gauges and info readouts or use the ones in the library of gauges. After you conquer the learning curve required to use it, it gets easy.
