ESC life time
ary
My octo fly like limpy dog..
bumpy & constant altitude drop, even in light winds
Other parts from my octo are solid. So, Im sure problem from ESC
It happend after my last assignment, I found 1 motor fail to start because of 1 cable disconect from esc. Is it can cause ESC timing error? Should I recalibrated it? I use DYS 40 A OPTO Simonk
Or its about time to find a new ones?
From my last two assignment put my octo in harsh condition, very hot & very humid(37+ Celcius 95% hum) including heavier payload 8kg+. Motor & ESC temp 60 drgree+ after landings
Appreciate for any input from MR forum
Cheers,
Ary
jes1111
I would check the capacitors on your ESCs - if there is ANY sign of bulging on the top (where there is a "cross" cut into the metal) then they should be replaced. If you suspect the ESCs anyway, then the first thing to do would be to replace the capacitors on all of them. It's easy to think of bearings as the only part of the copter subject to wear - but the capacitors on your ESCs also "wear out".
Note: I'm not saying this is definitely the solution to your problem - just one thing you can do.
ary
Thanks Jess,
but No bulging are found
Should I recalibrate/throtle calib. all esc?
Or should I move to another suspect? WKM? Should I reload/downgrade to 5.16? Im using ver. 5.20
There's no other suspect. Others are perfect
Ary
ary
Finaly I found it. Reload WKM firmwire(5.20), compass calibration, thats it... Smooth flight again
Last time I do that was more than 10 month ago
My esc are doing just fine. no bulging/error
Ary
Thanks Jess,
Ary
