esc help???!!!
Teco
i din't kmow where to post this, so i am sorry if i am on the wrong thread.
Well, i need ESC for my carboncore OCTO, i am looking for these
http://www.mikrokopter.us/shop/maytech/mt40a-mt40a-opto-v1?sort=rating&order=DESC'
the other one its the same but says that is for multirotors only, right now i use dji 30a on my CC H6, i like because i don't need to program.
the other is this one >
http://www.mikrokopter.us/shop/mayt...multicopter-esc-simonk?sort=rating&order=DESC
any one can tell me the difference ?
thanks
Teco
RobertsUp
Teco I'm also using 770KV motors and I recommend this esc:
http://www.altitudehobbies.com/maytech-eagle-multi-series-30a-multicopter-esc-opto-simonk-1?search=esc
I also don't want to mess with programming esc's. They're optos. My quad using those esc's w/ SimonK responds instantly and smoothly. Throttle control is smooth and precise. Website says they're out of stock. There's probably a good reason for that. Wait for 'em
Someone wrote that those Maytechs are just rebranded Chinese units. Maybe, but I got them in 3 days. Mine are 40 amp. That shop doesn't list those anymore.
Rob
thanks
Teco
RobertsUp
I saw that video before. That's exactly the kind of programming nuisance I wanted to avoid, same as you.
The esc's are pre-flashed with SimonK. They can't be reprogrammed at all. Throttle calibration is still required. Yes. In your DX8 lower the throttle left travel value to -120. Calibrate the esc's and afterward go back into the tx and return the throttle travel to 100. Another forum member right here taught me how to do it. Installs same as the stock DJI optos. No fussing with needing a different bec. Plug & Play.
I went back to that website and found that the 40 amp SimonK Opto is back in stock. While there I wrote a review. It awaits webmaster approval. I would snap that esc up. Altitude Hobbies gave me good service.
It's the same esc you saw at mikrokopter.
http://www.altitudehobbies.com/index.php?route=product/search&search=maytech esc
Best, Rob
SO,, they don't need to be program? but i have to setup the end points right?
i found this, take a look
http://www.youtube.com/watch?v=zJknmXFyghU
thanks
Teco
just ordered the ESC,s, so i have to put the throttle in -120 on the traveling adjust to do the end points?
thanks
