DYS Tiny Combo Set F1104 for 130-160mm Multirotor
Nancy Ye
Hi Friends,
DYS released F1104 tiny combo set for 130-160 mm mini multirotor. It comes with 5.6g BE1104 4000KV brushless motor, 7.2 g XM10A mini ESC, and ABS3020 prop.
The box list is below and have a nice box package.
E1104 4000kv, whole black color *4pcs
Mini 10A esc working with BE1104 motor* 4pcs
ABS3020 Prop *3 pairs
You can build your mini quad.
XM10A esc is designed to work for high KV value and can support oneshot function, it is BLHeli bootloader and BLHeli firmware.
Attached the related data of BE1104 4000KV motor for your reference:
Specifications:
KV..............................................................................................................4000
Configu ration....................................................................................NP
Stator Diameter....................................................................................14mm
Stator Length..........................................................................................12.5mm
Shaft Diameter.......................................................................................1.5mm
Motor Dimensions(Dia.*Len)...............................................Φ14×12.5mm
Weight (g)...................................................................................................5.6g
No.of Cells(Lipo).....................................................................................2S
Max Continuous current(A)............................................................3.5A
Max Continuous Power(W)...........................................................38.9W
Internal resistance..............................................................................Ω
ABS3020 Prop:
With 2pcs thread hole to fit the motor to save the adapter weight.
Welcome to build an order.
