Razzil
I've got a newly built Droidworx CX600 (hex) for sale. Everything is brand new, flown once for testing.
All parts are from Droidworx with the exception of extending the front POV and rear battery mounts.
I extended them for easier removal in case you ever need to remove the bottom canopy portion.
The main distribution board 8 is wired for the main voltage while the smaller board is 12v (leds, gimbal, etc...)
What you see listed below is for sale, I'll only split things up, if everything goes.
Six motor wires are braided and covered in mesh as well as the LED wires going to each arm.
The two rear arms are bright blue, while the remaining are all bright white LEDs.
Spare motor mount on the rear arm for mounting the GPS puck. So you can take off the canopy easily.
I've spent a lot of time getting everything neat and tidy inside, with the wires all the right lengths.
Selling because I don't have time to use this machine as much as I'd like to be.
Loads of room inside for an A2, iOSD Mark II, Zenmuse H3-2D modules ... as that's what I had mounted.
- Droidworx CX600 Hex
- Droidworx Power Distribution Board 8
- Droidworx Power Distribution Board 4
- Droidwrox AXi 2814/22 740kv motors (8 in total, 2 spares)
- RC-Timer 13x6.5 carbon fiber props (8 pairs, 16 in total)
- DJI 30amp OPTO ESCs (6 soldered to the PDB-8)
- Photohigher AV100 tilt axis gimbal shown
- Photohigher CX113 tilt/roll axis gimbal with spare servo
Everything listed above is $3500US before shipping, duty and taxes.
If you're interested, send me a message as I'd like to get .... $3000US
