1) what does pwm frequency specification of esc signifies?
Depends on which PWM spec you're talking about. Update rate is the frequency at which fresh speed command data is "pushed" to the ESC. Typical figures are 400Hz for most EFCs. Most modern ESCs are OK with this, some aren't. True PWM frequency is the chop rate of the DC that's provided to the motor. A typical figure is 8kHz, some are 16, 24, or 32 kHz. Don't worry about this it inherent in the ESC design and is OK for all motors. The higher figures won't be audible, so there won't be any "arm-whine" that is normally heard.
2) esc's (4 in no) would be operated by pwm or servo signal with arduino?
The Arduino based EFC will provide a command signal to the ESC that is the same as one provided to a servo. The ESC will translate this to a motor command.
3) does frequency of servo signal of arduino has to be changed for controling esc's (4 in nos) in accordance with esc frequency in it's datasheet?
Not necessarily, see above description.
4)What is the relationship betwen bldc motor 's thrust with it's kv?
K-sub-v relates motor operating voltage to RPM, see Wikipedia for more info. With a given propeller, a higher RPM will result in greater thrust up to a point
And what is the optimum kv rating for an quadcopter?
Multis typically have a low Kv rating vs. fixed wing aircraft or single rotor Helis. this is becuase, essentially, the props are almost always in a stall condition. SIngle rotor Helis use gear reduction to drive the rotor, not so in a typical multi. Increasing the RPM beyond a certain point worsens losses and overall system effciency drops as a result. The optimal Kv depends on battery pack voltage. 3 cell typically would use a 750Kv motor, give or take some, and 6 cell packs would use a 360Kv or so. There is much "wiggle room" in these estimates as much depends on prop choice.
5)Which is the best filtering for imu?
None! If the drive system is vibration free and the airframe is suffciently rigid, no filtering should be neccessary for stable flight. I don't have any filters running in my 585.
6)how to change servo signal frequency of arduino?
Depends on whose EFC code you're using, if it's adjustable, usually it's in a configuration file somewhere. In MultiWii it's in the config.h file, others, I don't know.
