DJI WKM Failsafe error
bluefog
Hello specialists,
when i took off or lost signal from my spektrum transmitter, the wookong won´t go in failsave mode. It tooks the motors off and fall from the sky.
The error started after 20 - 30 flights, before failsafe worked fine.
please help, bluefog
To set up fail safe you need to program your r/c receiver, normally you would set the r/c transmitter controls to the fail safe position (you may have to adjust the end point of the gps/atti/manual switch) and then get the receiver to accept that data. Once completed you would then return the r/c transmitter controls back to normal again.
