Aervolution
I'm downsizing my multicoper business due to demands with my main job. I'm selling my s800 EVO which has been used successfully on several BBC1 high end productions this year. It flies perfectly and the shots are beautifully stable. The Zenmuse is for the Lumix GH3, but has been modified to operate with GH4, both cameras can be used. The package includes the following:
DJI SW800 EVO
Zenmuse Z15 GH3 (modified to carry GH4)
DJI Wookong M (IMU V2)
2.4 Data Link
LED BTI
IOSD
Spare Blades
For more info please contact me, I'm happy to provide more info.
£2450
Below is some general info taken from DJI website.
DJI S800 EVO
This is the DJI S800 EVO HexaCopter section from DJI Innovations; this multi-rotor HexaCopter aircraft was designed and developed for high end users who require the very best equipment for aerial photography, search and rescue missions, or surveillance activities.
The S800 EVO Spreading Wings has many innovations which allows for rapid deployment in the field while keeping the space required for transportation to an absolute minimum. The removable arms can be swapped out (ESC, Motor, and Propeller) without tools in a matter of seconds and then refitted with the “snap in” action. The use of snap in arms also has the additional benefit of being able to quickly replace an arm if damage has occurred from a hard landing or if the S800 EVO has had contact with a structure while in flight, the down time is greatly reduced due to the very quick and easy “snap in” arm system on the S800 EVO.
The DJI Wookong WKM AutoPilot system is recommended with the S800 EVO HexaCopter for the best possible flight experience. With the Wookong and the DJI S800 EVO large-radius turns, precise hovering, and maintaining constant air speed has never been easier!
LED-BT-I(Bluetooth Indicator)
The DJI 2.4GHz Datalink is designed for use with the DJI Ground Station iPad app or PC programme. It provides a connection between the Ground system and the Air system using DJI bidirectional data communication modules, allowing users to fly along pre-set waypoints.
iOSD MARK II Features
DJI SW800 EVO
2.4 Data Link
LED BTI
IOSD
Spare Blades
£2450
DJI S800 EVO
- The WooKong-M now provides assistant software for iPhone4s, iPhone5, iPad3, iPad4, iPadmini, iPod5. You can adjust parameters at any time on your mobile device only through an LED indicator with a built-in Bluetooth module which makes it easy and convenient. It uses low power Bluetooth to minimize the power consumption of your mobile device,is easy to use and will automatically save your last connection records. The password mechanism ensures your safety link. Parameters can be automatically synchronized to the Cloud Server and can be restored immediately when you change your mobile device.
- Highly integrated, beautiful and practical, compact size
- Support DJI professional autopilot system
- Real-time accurate flight data & video signal superposition
- Support double video source input, switchable during flight
- Remote video link channels in real-time switch
- Flight Log Function
- Free Upgradable Online
- Built-in BEC module, support 3s-6s LiPo
- User-friendly Assistant Software
