DJI Release Ground Station software v4.0.7
Kentjjl
Iam having problems with it. Do not download it does not work it's a bullsh t.
Jem
I don't know what they've changed but I can now get it to work on my new windows 8 machine. Just got to field test it now.
aWanderer
What setup is required to use this? I mean, can you use it with an F450, Naza and GPS or do you need the upper WK model setup?
aWanderer, the ground station / waypoint feature is currently limited to the Wookong, and also requires a datalink module (900MGz or 2.4GHz). And yes, an F450 would work.
deluge2
It should be here:
http://www.dji.com/download/wookong-m-waypoint-downloads/
but at present there is no active link (zip file). Not sure why the sw is preceded by '@' as this is convention is usually for firmware references for which there is never a link because firmware files are downloaded directly by the appropriate Assistant software. Since the file date is 6-SEP-2013, DJI may just not have it loaded yet or there is a configuration mistake in the webpage. Suggest checking back there later...
Steve
where can i download the dji
ground station plz
Rainman
Looks like 4.0.9 has now been released, however my GCS isn't seeing the update and not downloading anything.
