You really need to do some research. Not trying to sound like jerk but your set up for future crashes.
First thing is you need to figure out what you want to do with your copter, i.e carry a specific weight, and have a specific flight time.
The motors you bought are better suited 5S and 6S batteries and larger props. RC timer's chart gives you some idea of the current draw with their props, but this may be 100% accurate on how your system will perform when under load.
JST's are not optimal for the main ESC's power to power motors of this caliber you need something with thicker gauge like 3mm bullet connectors. The current draw on these motor scan be up to 10-20amps depending on several factors such as the battery, the propeller size and pitch. These motors are designed to give higher torque at low RPM's. They are best suited for larger props. They don't mention it, but I would guess theses motors to be the most efficient with 15 inch props to get the most flight time with 6S batteries.
Once you have a system dialed in with a specific battery you really can't just reverse and put a lower Voltage battery on unless you understand the limitations.
Do things like run E-calc and confirm what props and batteries work best for your motors with the desired weight.
I would suggest researching other peoples builds and see what there results are as well and then match those builds.
Big picture the power system is not the system to take short cuts on. Its the most critical system on these.
