dji a2 two purple flashes
Benjamin Kenobi
Easy? You call that easy?
What about the movements on the assistant program? Throttle up is slider right. Aileron right is slider right. Rudder right is slider right. If any of these are moving incorrectly then use the reverse function on the assistant. You can't reverse throttle direction on the transmitter itself from recollection (can't as in shouldn't).
This is how you perform a CSC:
Any help?
I've already said all of this...
I have it all set up correctly. DJI just told me that firmware 2.2 for the A2 is bad and is preventing the motors to start up. They are working on new firmware now.
One of your Youtube videos shows 4 x 8000 maH batteries stacked on the hub.......
tell us more about your MR?
It looks like a Cinestar 8 with long motor arms.
Did you run your design thru eCalc from Multirotors?
