Diatone #17 Racing FPV Quadcopter Drone BNF
Brian M
Professionally assembled Diatone #17 V3b 230 mm G10 racing quadrotor frame with high performance T-Motor 1804 2400kV motors.
This is one of the premier setups for exciting mini drone racing, acrobatic flying, and aggressive proximity flying. Low profile and low moment of inertia setup for super responsive handling. ESCs are sandwiched between lower two plates to reduce m oment of inertia in all three axes (pitch, roll, and yaw) and provide better protection. Vibration is isolated from the camera(s) by rubber isolators mounted between the propulsion plate with the motors and the upper section. Flight controller settings can be tuned to your flying style, but this is not a toy for kids. Always fly responsibly.
Battery and receiver are included, so just add your Spektrum transmitter, FPV gear (optional), and GoPro or Mobius HD action camera (also optional) and you're ready to go! Includes the harness for your FPV camera.
SPECIFICATIONS
Frame Width: 230 mm
Frame Height: 85 mm
Flying Weight: 16.5 oz
ESCs: Velotech Magic Multirotor Speed Controller 12A, 1A BEC, SimonK (2-4S)
Motors: T-Motor MN1804 2400kV (2-3S)
Propellers: 5x3 carbon fiber
Flight Controller: OpenPilot CC3D running latest firmware (V15.01)
Receiver: Spektrum AR610 6-channel receiver
Battery: Glacier 3S 11.1V 2200mAh lipo w/ XT60 connector
Flown once to confirm airworthiness and dial-in initial settings. Very easy to tune for your preferred flying style. No returns.
