Aeronavics / Droidworx CX600 build
nicwilke
I'm using the Xaircraft SuperX, so it's a little difficult to compare. You should get around a kilogram of thrust per motor at 75% throttle, so if your all up weight is about 2kg, you'll have a good rig if you tune it in well. Try changing gains up first. Go in 10s, and set and fly record on paper the settings, followed by results. Don't fun fly, just up, hover, land. And write down a result from 1 to 10, 10 being perfect and 1 being wobbly. I know it sounds clunky, but yoy will always have a point where you go to far, and then you know from your writings what setting yoy can jump back to. Good luck
Sent from my GT-I9305T using Tapatalk
koptercam
RED Epic or ARRI Mini? Both!
Thanks a lot mate!
My all up weight is 2.7kg and still got the GoPro Zenmuse to go on, so will probably be around 3kg when all said and done. Maybe i might have to jump to 12 inch props.
I'll play around with gains as you mentioned... might see if i can get indoors somewhere so i don't have the wind factor to consider either :)
Thanks again for your advice!
nicwilke
Here's how I mount my gimbal now. Custom made carbon fiber mount.
nicwilke
No, it's a fpv camera. Probably won't use it much, but it's hooked up.
nicwilke
Here's my new gimbal and battery mount. It holds a 3 axis gimbal for yaw smoothness.
SleepyC
www.AirHeadMedia.com
This SuperX is seriously the best flight controller I've ever flown. Yes, best. It is so stable, and flys fluidly. I'm used to Naza and ZeroUAV YS X6, and this thing is incredibly good.
100% agree. It is so much better than anything out there for the smoothness and feel.
SleepyC
Sleepy, I have a basic and a pro. Both faultless.
Yea, I have a (1)basic, (1)standard and (2) pro ( changed all my rigs from Hoverfly) and they have been amazing. The only thing i had problems with was trying to put on on my XY8 coax, it did not like that config, but the engineers sent some ideas, but honestly that rig flys so well on the HFP I’m just leaving it and hoping the GPS gets better. BUT any new rig I build will get a SuperX... so easy to set up and so consistent. I have a similar go pro rig as your CX600 (just a quad frame us version, but all good running gear) and i have around 55 flight son that rig now, and it’s been FLAWLESS.
nicwilke
So excited to test this in the air tomorrow. No slop on the mount, its as rigid as hard mounted, the only wobble is from the actual anto vibration, as per normal.
Cuba59
Hello, Question,
how easy is it to mount a Zenmuse 3D on the CX600? is there enough "material" on the centerplate to attach it?
