Hi newcommer here. I've only recently plunged into this whole jungle of parts and terms. I've started a thread here, basically also to be helpful for other who just start out.
On the way though I see stuff which gets me wondering what it means. So I'll just post those questions here:
Q1.: just encountered this: http://www.hobbyking.com/hobbyking/..._2209_980Kv_14Pole_Multi_Rotor_Outrunner.html
which is a 'short shaft version'. Now I get that the shaft is shorter, but what are the implications of that?? From the specs and the drawings it appears that the length of the shaft is actually 0, if so, to what do you attach the propellers?
Q2: thrust: its quite clear that it depends on the combination of motors and propellers. I'm thinking of a hexacopter which probly comes around 2.4kg meaning I need at least 5kg thrust which means that each motor has to have at least 833g of thrust. But its very hard to find any specs in regard to that. Can someone advise me in this? Either name some motors or a site where you can calculate this (im aware of ecalc but that still eludes me).
