Hi Guys,
I'm buying an AP/AV platform at the moment considering a DJI F550. I've flown helis for years and as I consider the platform the other questions that arise are the gimbal and camera. After I did my initial research I came away thinking (and stuck on) the RX100II. Trying to find a gimbal is a bit tough.
So:
Will the F550 lift a gimbal that will hold the RX100II (given the reasonable "other " equipment, battery, naza, etc)?
Controlling the RX100II in the air, as in triggering the camera, can only be done with a servo trigger, correct?
Starting the video capture on the RX100II is done from the ground prior to lifting off correct?
I'm thinking of the RC-Timer brushless gimbal for the NEX. I've seen several examples of suitable videos. Good, bad or indifferent?
I am not able to spend 5-6K on a system and as it is with the above mentioned equipment I'm at around 2.5-3K, thoughts?
I have some friends pushing for the S800, but $$$$, then there is the Carbon Core frame RC-Drones.
Thanks for any/all responses.
Scott
So:
Scott
