ChrisLoughlin
I have a Naza-M V2 in a DJI Phantom using a Spektrum Tx and Rx with a TM1100 telemetery unit. I've just changed the main board after having some voltage issues (Rx voltage dropping to 3v in flight). Connecting up again everything looks fine -and the Rx voltage is now correct. I've done a motor test and recalibrated the sticks. All good so far. In the Assistant Software, the black Control Mode switch indicator on the U channel shows that it's moving to the correct mode (Atti/GPS etc) on the position line - BUT, the Blue indicator bar will only jump between "Failsafe" zones.
If I flip the failsafe switch on the TX -the black indicator moves to a failsafe position. (as it should) - and then returns when I cancel failsafe.
If I power up without plugging the NAZA into the assistant software - the LED indicator shows normal status. And if I switch to Failsafe RTH on the Tx - I get the correct fast Orange flash. Switch back and the LED shows the normal display.
Has anyone seen this before? I'm wondering if the Phantom is fine and it's just something weird with the assistant software. Any wisdom appreciated. (I did a re-bind on the Rx by the way - no change).
Chris.
Chris.
