First here is my setup I am having built:
DJI F550
Zenmuse H3-2D (also utilize tilt)
Naza-M V2
iOSD Mini
DJI 5.8GHZ
Futaba T8FG w/ supplied receiver.
I know traditionally you would just connect the outputs from the receiver into the Naza-M, and use 7 channels, leaving an 8th channel free. My intention is to use that 8th channel for a retractable landing gear that I found from a seller in the UK.
If I went with the newer S-Bus method, I know only one connection goes from the S-Bus port on the receiver directly into the Naza-M. In this scenario, would I still be able to use one of the additional opened outputs from the receiver to control the landing gear's up/down channel or once the S-Bus port on the receiver is utilized, the rest of the outputs on the receiver will not work?
Bear in mind, if using S-Bus, and the landing gear channel on the receiver I still want all functionality to work such as tilt on zenmuse, Atti, GPS etc., return to home, and IOC.
I have seen mixed answers regarding if this will work. The builder said it won't, but some of the research I did says it will and some says it wont.
Any input? Thanks!
DJI F550
Naza-M V2
iOSD Mini
DJI 5.8GHZ
Any input? Thanks!
