Problem. All motors arm and are are calibrated direct from the Rx, but won't arm when connected to Naza MC. I am using a Turnigy 9x latest release from Hobbyking. I list below my step by step configuration settings for the transmitter.
System
Typ sel. Heli
Heli 1
Mode. PPM
Stick set. Mode 2.
Settings.
REVERSE. PIT only
THR/CV. 000, 25, 50, 75, 100.
PIT/CV. Top position Aux3 switch. All set to 45 for Att. Middle position all set to 85 for Manual. Bottom position all set to 30 for Fail safe.
SUBTRIM. All 000.
E.POINT. All 100.
THR HOLD. State INH. HOD pos 000.
AUX-CH. 5 Null, 6 Null, 7 Pit trim, 8 Hov pit. 9 Null.
D/R&EXP. Off
TRIM. All 001 [ 000 ].
REVO/CV. POINT NOR, All 050.0.
FAIL SAF. ALL NOR.
HOV THR. INH.
HOV PIT. INH.
TRAINER. INH, ALL OFF.
DISPLAY. ALL WORKING.
TIMER. INH.
GYROSENS. INH.
STNTTRIM. INH.
PRO <123>. Mix 1 INH, MIX 2 INH, MIX 3 INH.
That completes every available setting in the TX configuration. If any body can see anything obvious or could post your working settings I would be most greatfull.
System
Typ sel. Heli
Heli 1
Mode. PPM
Stick set. Mode 2.
Settings.
REVERSE. PIT only
SUBTRIM. All 000.
E.POINT. All 100.
D/R&EXP. Off
FAIL SAF. ALL NOR.
HOV THR. INH.
HOV PIT. INH.
TIMER. INH.
GYROSENS. INH.
STNTTRIM. INH.
