You mentioned you apply throttle up AND yaw left... it is my understanding that you'd apply throttle up and to the left only (while everything else is untouched). Source: http://www.mkmanual.com/systems-calibrations
Gyroscope (Gyro)Calibration
The micro gyros on the MK are very temperature sensitive and this calibration must be done every flight in order to stabilize gyro temperatures in preparation for flight.This calibration is necessary because the sensors have a series of scattering and temperature dependence (also the resting values of individual axes of the acceleration sensor are different). Procedure:
1. Place the MK on a stable surface an do not move it. note: the MK does not have to necessarily be perfectly level as the Flight Controller will be using the stored "level" reference made at the time of ACC calibration.
2. After applying power move the throttle up and to the left until the buzzer beeps and the green LED goes out. (Thenumber of beeps corresponds to the setting number.) Remember: only the gyros, are calibrated in this procedure, this does not set level as with the ACC calibration.
This process also powers up other components of the Flight Control board and prepares it for motor start.
