Mikrokopter Come home speed
RTRyder
Merlin of Multirotors
Q; Can the come home speed be speeded up or slowed down?
If So How:confused:
I believe the GPS D limit setting in Navi control will change the speed that Mk moves between GPS points, make SMALL changes and test fly each time you make a change as you never quite know what else will be affected by changing any one parameter.
You can also play with "GPS angle limit"; when set to 100, the model will bank at 17°, so you could lower that, for the model to take less speed.
