Mikrokopter Cinestar 8 with mk2.1 gps not working. Need help
rsheehan79
I get no gps hold at all. The blue light blinks but has no effect on the f.c. I was wondering if I could get some help here
Jason S
please post what some screens shots of the mktools,
have you checked your switches to make sure your activating ph and comehome?
have you checked the two ribbon cables that attach the NAVI to the FC board? also check the molex cable that attaches the GPS board to the NAVI. It's easy to misalign the two ribbon cables or to attach them without lining up the #1 pins correctly.
Hi, if you check the mktool. Does he see the GPS? You should check the molex
Verzonden vanaf mijn iPhone met behulp van Tapatalk
good suggestions :)
does the beeper beep (about one per second) when you select position hold? the beep would indicate that a GPS mode is selected but that the flight control can't satisfy the request.
