(Cheap) MK GPS V2.1 (SMD PREASSEMBLED)/ GPS SHIELD 11
I am selling both these items for 90.00. The price of them together is originally 126.00. They have never been used. Please contact me at [email protected] if you are interested in purchasing them.
This is an MKGPS receiver with u-blox LEA6S GPS module and a passive antenna.
Alternatively, the module can also be operated with an active GPS antenna.
In connection with a NaviCtrl V2.x the MikroKopter can self-navigate Preassembled; there are only a few through hole components for self-assembling.
The board is tested and pre-programmed for use with the NaviCtrl board.
Scope of delivery
1x board (SMD-preassembled)
1x passive GPS antenna
1x cable with connector (5pin)
NaviCtrl or MK3Mag not included in delivery
GPS SHIELD 11
This cover made out of PCB-material is attached directly to the MKGPS board. The side panels are easily connected using solder. This is also the ground plane for the GPS antenna. This increases the GPS reception. The signal to noise ratio for the rest of the electronics in MikroKopter is increased.
Technical Data
• PCB-Material: 1 layer, 0.5 mm thick
• Soldermask on both sides Black
• Weight: about 10g
