Can I do this?
Tomstoy2
AM SimpleBLG, Futaba t8fg using s-bus. Is it possible to hook up the tilt control to one of my empty servo ports to control the tilt function?
PeteDee
Mr take no prisoners!
Yes as long as you also have a channel you can plug into, I am using channel 6 or 7, I also use one for switching video between the FPV cam and my GoPro, I am doing this using a 7008SB Rx and it works fine. if you are using one of the smaller Rx's that only have three connections you probably cannot do it. I am using 14SG but will be the same.
What Rx are you using Tom?
Pete
