is it better to calibrate all the ESCs at once? If so, do you just hook up all the ESC to the naza and the throttle port from the naza to the receiver and calibrate?
Actually it is easier and less time consuming to do all of them at once. You'll need a 4 in 1 or 6 in 1 (depending on what platform you are using) harness. You can make one or order one http://www.ebay.com/itm/NEW-8-in-1-...535?pt=LH_DefaultDomain_0&hash=item2edca409bf. you have to connect it to your radio Rx into channel 3 ( which is your throttle channel). Don't use the Naza Controller to throttle calibrate your ESC's. Turn on your radio set the throttle to high power up the Rx and listen for a beep from the ESC's telling you have the high limit set. then lower the throttle to lowest setting listen for a beep and you have set the throttle range for all the ESC's .
