building hexacopter with DJI WKM
Hi Exopackshiu
here we are finally I got everything the ESC the frame the connector and so on could u plz let me know your electric connection specially using 2 batteries and so on thanks in advance
Hi Paktazh,
Here you go…! I'm attaching some pictures of mind, also give you the link to Hobby King ( base on their product code EC5) http://www.hobbyking.com/hobbyking/...ry_Harness_12AWG_for_2_Packs_in_Parallel.html is too big, mind is EC3 (it's call lead connectors )
Shiu
View attachment 3884View attachment 3885
paktazh
Hi
I figured out the wires but I am kind of confused about the the wires that goes to my Futaba 14 channel receiver it is unlike the Xaircraft that all 8 wires go to the receiver from the Xaircraft but in the Dji it only give you 5 ( A /E/T R/u )wires that goes to the receiver and the rest does not have any wire connection unlike Xaircraft to control the Gimbal ? if not connected to the receiver how do u control the gimbal
thanks in advance
Do I need to buy Futaba S-sub to be able to do that ?
paktazh
Mine is a Hex copter with 14 ch receiver and 9 ch radio in the DJI manual it shows that one has to connect the Gimbal to port F1 and F2 but on the opposite side of DJI it does not showes that one has to connect any port for gimbal to the receiver ?
Hi Paktazh
you can choose whichever you like ( x1x2x3) I'm using X1 for gimbal ( tilting pan) X2 for gain adjustment last one X3 power up the MC with the BEC
paktazh
regarding the ESC connection unlike Xaircraft the wires are all black how do you set them forward and backward
paktazh
got it thanks
My Gimbal is 3axis it goes to 3 direction is there any way that I can use all the 3 function of with dji as manual only shows just the 2 wires goes to the DJI
or if not isthere any way that I can control the gimble some how with the radio without connecting t to DJI like this one
http://www.youtube.com/watch?v=H8sCIw24Cqo
got it thanks
Hi Paktazh
if you want to Gimbal to do 360 degrees rotational with your Alware three Axis it's require lot of modification ..! but for now you can plug straight to the RX assign a channel with your radio or ( slider) let us know rotational amount...
Shiu
paktazh
Hi
I got some problem with software i did upgraded the firmware the DJI flashing blue and my Futaba receiver flashing green but could not make the motor to turn on the motors are doing beeb when i turn them on so it means they other then that noting else going on also could not figure out this software is there any video tutorial around guys
regards
Hi
regards
Motors won't turn ? make sure no props installed during this test, must be disconnect from the PC, power up the Bird, RX must be in GREEN and MC must be in RED from your Radio control pull down both sticks same direction ( corner to corner) motors will start if you keep the throttle below 10% it will shut off within five second above 10% steady run…..!
paktazh
I did that but nothing happened the DJI Led indicator keep flashing red and the futaba receiver flashing green
by the way great shot waw that must be ur home since i seen it in the winter
it shouldn't be flashing, double check your connection correctly inserted as per manual from MC to RX also must be calibrated thru Dji screen ....!
Yes my home plus other two Homes Family members ,Thanks
paktazh
The Futaba receiver is not flashing now but the DJI is showing a blue light when i upgrade it then could not figure out how to do the the software things there should be a video made by DJi but I guess not
During a Firmware upgrade MC led become a bluish it's a normal, Browse around the Dji thread you will find it all the information you need, but if you still don't find enough information i will try to make a video for ya let us know
Shiu
