Looking for some input re batteries. I have built an Octo Copter. I have 2 5000 65-130 C Batteries I put in parallel. After 5 minutes of flying as a test one battery took 3273mah and the other took 735mah. Is it normal for them to not go down evenly. I'm trying to figure out if I'm better off to run 2 in parallel or get one large battery. I have found a 10,000 mah battery at 25C continuous. I'm running 8 Avroto motors and they say the max power at 14.8 volts is 390 watts. So I figure that is about 9.3 amps per motor or almost 75 amps.
Rich
Rich
