Batteries can I use a car battery?
farmerfred
Hi,
I have a few DJI components such as the IOS ground station that require a "3s-6s" battery. So my question is can I use a normal car battery to power these things?
A 3S battery is simply a 3 cell battery thats producing 11.1v "ish" and so as far as i can see it should be the same and therefore ok?
the short answer is yes. but why? Normal car batteries or lead acid offer no benefit over LIPO's. If you were just bench testing then sure... but may as well get yourself a bench power supply which you can vary the voltage. very handy tool for testing all sorts of components.
farmerfred
because when Im out in the field I could simply clip onto the car battery for things like the IOS ground station that need a good stung supply but don't need to be moved. Also saves carrying extra unnecessary equipment round too.
Hi,
12 volts is 12 volts. The equipment doesn't care where it comes from.
