Double post from: http://forum.mikrokopter.de/topic-40812.html
Reading the Manual about this:
http://www.mikrokopter.de/ucwiki/en/MK-Parameter/Configuration
"Axis-(de-)coupling (Achs-(ent-)kopplung)
Here you can enable or disable the axis coupling. The axle coupling prevents the MikroKopter after a curve is flown to be loopsided.
Function is active when the yaw angle will be corrected internally. This function should always be activated!! "
And the tab "Coupling":
http://www.mikrokopter.de/ucwiki/en/MK-Parameter/Coupling
I read the coupling as a function that mixes nick/roll stickmovements to the yaw. Something would be great for acro flying, but horrible with for AP/AV.
That leads me to my question, the tickmark in "Configuration" does that couple or de-couple the axis?
