gtranquilla
RadioActive
Testing the new 32 bit 3-axis Alexmos SimpleBGC on a Cinestar with the tripod landing gear/yaw motor cage and a GoPro3+.
Normal configuration "heading" mode seems to work really well.... but I am having issues with the "Follow Mode" for Yaw.
The GoPro BGC is the RCTimer extra light 2 axis IMP BG. But to account for the extra angular momentum of the tripod landing gear that rotates with the camera on the yaw axis, I installed an iPower GMB4008 150T 22 pole BG motor.
It work ok when ground tested in a sling but in the air is a different story. It will work for awhile but with sudden moves of the MR in the air, it will lose its alignment with the front of the MR and rotate randomly for a while then settle down in the wrong direction as it is supposed to follow the front of the MR all the time.
Has anyone here been able to tame the yaw axis in "follow mode"?
