Anyone who has known me for the last few years knows I have not given up on making a torus shaped heli.  There are a few reasons I like this idea but another one came to mind.  If you imagine the wind flow of a prop over our typical radial arm designed helis, you can imagine that the airflow is disturbed(much like myself) when it passes over the arm.  But what about the fact that it is disturbed ONLY on one half of the blade?  This must make some kind of vibration where the blade passes over thin air on one side and the other is conflicted with the resistance of the arm in its way.  So let's move forward to my idea of the ring/torus idea.  You would have double the amount of surface in the way of the props as each time the blades passed over the frame, they would both be encountering an aerodynamic obstacle.  So the question is, is it better to have more flow resistance but equal on each blade simultaneously or is it better to have less resistance but unequal loading on the prop?
